1 - 6 of 6 Posts
Hey guys,
I was doing some spirited driving on Saturday night in my 300KW R33 GTR. I noticed in my driveway on Sunday morning a oil leak. Found oil around the oil filter however it is fully tight.. Dip stick was also sticking out a little bit. There's hardly any oil left on the dip stick. Oil pressure is fine though on the factory gauge and no weird sounds in the motor and did not notice any power loss.
Gonna take it to a mechanic to do compression and leak down test. Did some research and apparently, the dipstick only reads about 1L from the bottom of it to the "H" mark. Is this true? If so, prob means I still have at least 3.6L in the sump? Has this happened to anyone else before? Attached some pics.
Yeah mine did that too much crankcase pressure, using oil, smoking , ring lands broken in the end, hope it's one off for you , wasn't for me ;-)
1 - 6 of 6 Posts
