1 - 13 of 13 Posts
RK tuning sell a blanking plate that you fit in its place. Ron recommends then. I have seen other brands about but I cannot remember where?
Ref price, £30 posted?
Surely you can just join the 2 waterlines together as ones a feed ones a return and fit your oil coller sandwich plate to the block and just fing a new home for the oil pressure sensor?
There is oil temp and pressure sensors in the housing. You can screw an oil filter straight onto the block and do away with the entire housing as you suggest.
I think the OP will get some advice?
Just be careful dude i noticed that the Temp Sender on the R32 is slightly wider than the ones on the R33 ...
I noticed this when leaving some ancilliaries already bolted to an R33 GTR block and connecting the R32 GTR sensor....thinking they were the same and werent
1 - 13 of 13 Posts
