Hello,
I'm doing a R33 RB26 swap into a S14 chassis. I've done the RB25 swap before, but first time with RB26. I've done a lot of searching but keep finding conflicting answers.
I know I need to use the RB25 rwd transmission and a RB25 clutch kit, and I plan on using the R33 rb25 trans with the push style clutch. But can I use my current RB26 flywheel and starter? The current clutch setup on my r33 engine is for a pull-style clutch, but I don't know what's different about the flywheel and starter between the pull-style and the push-style.
The part number on my starter is 23300 20P05 if that helps.
Thanks,
Sean
Thanks,
Sean
