1 - 12 of 12 Posts
HEY GUYS NEED SOME HELP
The engine is running a bit rich and will not catch up with a throttle
if i hold it at 1500rpm and rev it up (quick) it boogs and wants to die
if i do it slowly its fine.
Which makes it a big deal if I shift from gear to gear at above mid throttle i lose all power and have to wait for the engine to catch up
Any advices would be a lot of help
Discussion Starter · #8 ·
what i mean is: I had a pressure leak(not vacuum, pipe by inter-cooler before the intake was a bit loose) I fixed it and still the same.
I did go over with alternative fuel (propane) by all the hose connections (inter-cooler piping ets.) and i did not find any more leaks.
still have the same problem ( maybe i still have some leaks somewhere were i cant feel them)
By the way is there a software(laptop pc to usb to 14 pin connector) that i can connect to 14 pin connector and see my sensor readings?
Had the same problem, it was the enginetemp sensor that was broken.
(made the engine think it was cold, and added io mutch fuel)
Petter
1 - 12 of 12 Posts
