Hi Guys,
Im currently building a motor at the moment and was going to extend the sump for added oil capacity and peace of mind.
Someone has now said that they run a tomei pump with a stock sump. Is this corrcet or will the pump push all the oil to the head?
Thanks, any feed back would be helpful
Anything that moves more oil than an N1 pump needs an extension and a deeper sump is better than wider sump in my experience.
Absolutely agree with Alexj. I am using a Tomei pump in my build, my engine builder insisted I use an extended sump as there was a significant risk that the pump could empty the standard sump.
