1 - 6 of 6 Posts
Evening all, i need the following bits if anyone has them........
Oil outlet hoses and bosses for both turbos....
Block water (heater matrix) outlet bosses
14020HB & 14020HA
Need asap...
cheers, Ian
07956 446870
Not sure what bits you want, but think I have most of it.
Which part of the turbo oil return ? the bolt on or the rubber ?
I have a complete plenum and associated pipe work, so I probably have what you need. ;)
Get in touch.
cheers cokey
Hi cokey,
essentially i need the water inlet and outlet bosses on the plenum side of the engine and also i need the entire oil outlet pipes for both turbos....bosses that bolt to turbos, hose and bosses for the block.
Cheers, Ian
1 - 6 of 6 Posts
