Hi all
I have for sale freshly rebuilt rb26dett engine.the engine has only done 100miles since rebuild.you will get everything minus the turbos.engine was built by a ex burton motorsport engineer.I'm waiting for a email with pictures of the build.there is also reciets for the parts boughts.the engine is going to be coming out of a r32 gtr that I'm breaking and can be heard running.
Power fc L jetro no commander £300
4 pots with drilled discs £150 fronts only pads low
2 pots with drilled discs £100 rears only pads low
R32 gtr front seats with runners £250
Hks super dragger with decat £250
intercooler unknown make with greddy hardpipes 120mm thick £250
Dash air vents £80 posted
Veilside cluster 340kmh £200
R33 gtr wheels with good tyres 235 all round £300 ono
R33 gtr gearbox £300 ono Low milage gearbox converted to a push type clutch
Nismo clutch slave £80 posted
Nismo fuel pump £70 posted
Nismo boot spoiler with adjustable fins £100
550cc nismo injectors with nismo regulator on fuel rail £300 posted
oil cooler kit with relocation unknown make £100
Spec
Wiesco 87mm pistons
Eagle rods
ARP main cap and head stud kit
Arp rod bolts
Hks 1.2mm head gasget
Hks inlet manifold gasget
ACL race bearings
New water pump
Nismo timing belt
Reconditioned standard R33 head
greddy stage one cams (9.1mm lift, 272 duration)
Fidanza cam sprockets
Tomei oil pump N1
Tomei oil orifice in the block
R33 crank shaft (larger drive coller)
Standard plenum with injectors
Standard coilpacks.
Standard injectors 444cc
And complete engine loom
I'm after £2400 ono
Spec
Wiesco 87mm pistons
Eagle rods
Arp rod bolts
ACL race bearings
New water pump
Nismo timing belt
Tomei oil pump N1
Standard coilpacks.
I'm after £2400 ono
