1 - 15 of 15 Posts
i have searched but i could only find one other dyno run at 1.2 bar.
anyone got any dyno runs of gt2860-5 turbos or 2530s at 1.2 bar.
please post them here :thumbsup:
just thought it would be good to see different specs and results.
heres mine
2860-5s at 1.2 bar
9,1 264 cams
ported head and inlet matched
87mm pistons so roughly 2650 cc
the only dynoed 1.2 bar run I've ever done made a mediocre 430-ish hp at the wheels, redlined at 7000rpm. The car makes power through 8000rpm, and well, if you've got the balls and the map to turn it up past 1.7 bars, you'll make a lot more power I'll tell ya that :)
1.5 bar is next on the list with some 800cc injectors. not yet though pointless in this weather lol.
my wheel power peak with boost and afr curves
GTROC Member
This was from my old R32 @ 1.2 bar, built by Rob & Justin.
HKS 2530 Turbos
Tomei Extreme Manifolds & Elbows
Tomei Poncams (Type B)
Stock Head
...etc
2530 turbo's
1st sheet is on 1,28 bar (peakboost) when we were setting up for early response at a longer range.
This one is at 1,72 bar of boost. same as first one but then the final result at that moment on the same turbo's.
still 2568 cc standard block, standard internals. On E85 bio-ethanol.
Discussion Starter · #9 ·
looking good peeps, nice few results here now :thumbsup:
for 18 psi boost pressure these are some good power outputs imo. and all above 400 lbft :clap:
Discussion Starter · #10 ·
anyone else ? im hoping to have a new graph to add to this soon at around 1.7 bar.
i am running 2860-5`s @ 1.6 bar. i would be very interested to see what power figures they will make...
Discussion Starter · #12 ·
ive looked into this since i started this thread and the compressor maps give us a good idea. the center curve of the map is a good reference for boost - airflow.
1 bar 500 hp
1.25 bar 550 hp
1.5 bar 580 hp
1.75 bar 610 hp
2 bar 630 hp
if im correct i should see a GENUINE 600 hp at 1.7 bar.
1 - 15 of 15 Posts
