Hi, im running a rb25det and am fitting tomei 270 degree 10.25 pro cams.
Would just like to know if the standard rb26 solid lifters are ample enough to cope with these cams as i can access a set for pennies compared to lifters from tomei. I know about the gtr's running different length valves compared to the gtst but i can make the difference with made shims (hardened) so that shouldnt be a problem.
thanks for any advice all
