1 - 11 of 11 Posts
Very reluctant sale of my RB30/26 engine needing the cash to get married. I built this engine my self back in 2011 and only got around to fitting / running it in my s14a, april this year(2013).
I have put 3000 miles max on the engine from it being built. It was mapped on a link g4 and only run 1.2 bar. 2 weeks after having it mapped I decided to break the car and keep the engine to put in a GTR but unfortunately I now need the money. It has been sat in my garage for the last 5month.
If I was to keep it would be a good 3 year before I could do anything with it and just makes it a expensive garage ornament.
I will not break the engine it will come with everything listed.
Spec*
RB30 block ( has oil/water feed& return )
Acid dipped
New core plugs*
Tensioner relocated*
Crank coller fitted*
Crank polished*
Block lightly honed*
ACL race rod bearings (std)
ACL race main bearings (std)
Nippon Piston ring (gapped accordingly)
Mazda 323 timing belt
N1 oil pump*
N1 water pump*
Tomei oil orifices*
Refreshed RB26 head by [email protected] sky engineering
Head skimmed / tested & cleaned
Valves re cut
Head re shimmed*
Std RB26 cams*
Adjustable vernier pulleys
Std coilpacks*
Copper spark plugs*
Std intake set up*
34 gtr fuel rail & regulator*
Five0 Siemens deka 750cc injectors
RB26 polished cam covers*
Full oem gaskets.
RB25 head studs*
Full race style T4 twinscroll turbo manifold (sch10) new never used.
Demon motorsport Twin 44mm external wastgates (1 bar springs )
Custom RWD sump.
Un-chipped front pulley
Other parts that come with the engine are.
Viscous coupling/ fan
Alternator*
Starter motor
Cas sensor*
ignition amplifier
Other sensors on the engine.
Engine mounts*
RB26 oil sump inc diff*
Ally Rad with fan cowling
If you need a sump adaptor Leeroy25 is your man*
There's probably things ive missed feel free to ask. more pictures of the engine build available.
Price is £4500 + shipping*
Awww man. Go to Barbados to get married. Third of the price and buy a GTR with your savings :)
btw, we did the Barbados wedding..... brilliant.
GLWTS, and of course, the wedding :)
Thanks for the comments :) and I'll look into a Barbados wedding if it means getting back in a GTR :)
1 - 11 of 11 Posts
