wanted rb30 sump adapter to fit the rb26 4wd sump to it thanks
I've got one in steel,didn't like the idea of alloy,its the same design as r32combat's adaptor plate and was laser cut and then plough ground.It does need the holes, drilling yourself using your block and sump as a template.the fixings and fitting are listed in r32combats rb30 thread.you can have one for sixty quid if you want?thats what It cost me.
thanks guys got one sorted now cheers
