1 - 20 of 42 Posts
Hi all,
Some of you will have already seen my RB26 powered 34 drift car
Posing at Pod
RB26 - so pretty
Twin drifting with my best mate at DWYB
RB26, 2540s, PFC mapped for 540hp @ 1.6 bar but only ever ran at 1.2 as standard MAFs were maxing out
Awesome fun on the road but the lag of 2540s made it hard work to drift as power band is so narrow :nervous:
Rob was keen to try an RB31 in a rwd skyline and i was desperate to get much more torque so a plan was hatched :clap:
Should be ready mid may through nov :cool:
Rough spec of the top of my head
Forged TR Racing RB31
2860s-10s
HKS Fcon v-pro
Tomei Oil pump
Tomei poncams
Tomei cam pullies
Greddy Timing belt
HKS Fuel rail
700cc Injectors
Aeromotive FPR
Walboro lift pump for Swirl pot
Bosch 044
HKS hard pipe kit
Trust FMIC
Greddy profec B
Accusump
Exedy twin clutch
RB25 g/box
Nismo 2way LSD
GTR rear drive shafts
Lots of suspension and chassis mods to help it grip or drift depending on what mood i'm in :runaway:
Base block Nissan RB30 or OSG? :) Looking forward to see the finished engine! Keen to see what -10's will do on a 3 Liter.
Marc
OSG well out of my budget - i need all my cash for tyres LOL
Base block RB30 with 26 head :D
Im confused by reading the specs.RB26 is mentioned,then RB31 is mentioned
Is this car an RB26 an RB30 or an RB31???
Currently has a 26 - swapping for a 31 :cool:
Input Parameters Are the Following:
* Number of Cylinders are = 6 to 1
* Piston Diameter = 87.000 Millimeters
* Piston Oversize = 1.000 Millimeters
* Engine Stroke = 85.000 Millimeters
Computation Results:
# Computed Engine Displacement (CID) is 189
# Computed Engine Displacement (Litres) is 3.1
# Computed Engine Displacement (CC) is 3101.9
Above figures are not correct sorry, check Jabran200's post above, he has the correct figures.
Discussion Starter · #20 ·
Sorry, I just thought there was something a bit different about these TR RB31s.
Cant comment on other peoples builds mine is fairly simple
87mm pistons TR spec
Con rods TR spec
Headgasket TR spec
Stock crank
Spool crank collar
26 head with bronze valve guides and poncams
Jun Oil pump
N1 Waterpump
ARP headbolts
Im sure Tweenie can fill you in on anything ive missed :)
Have you run a -10 setup on any of your drift RB30s or do the NZ guys perfer big singles for the awesome fast tracks you guys have ?
1 - 20 of 42 Posts
