Hello,
I just install RC 750cc injectors. I configure in the PFC the new size to 59% (444-750 *100) and according to the latency of the injector (0.18-077) to -0.59.
After this, the car don’t want even to start. I change the latency to +24 and looks like is working fine, but running a little lean on boost even if i put +30(afr is 12) . I needed to set 1.100 in the inj temporary correction for don’t have knock.
Does anybody know the correct latency for these injectors? Or I’m making something wrong?
The FPR is stock, and the pressure is in normal levels.
