1 - 10 of 10 Posts
Hi all
I'm wanting to Re-build a RB26 engine.
I am curious to know where you buy your Main/Big end shells from?
What are the best make and in regards to the full engine gasket kit.. should i go for Nissan or are the aftermarket companies as good as?
I want to know what is the maximum power anyone has extracted from pump fuel (optimax+additives etc), no race fuels........i am wanting a solid 600bhp at the wheels, is it possible?
thank you,
regards
uprated is allways better when your messing with a crank.
i have fitted acl to a few cars , never had a faliure, even on ones where i should have had the crank polished:p
i would use acl.
regards sid.
ACL bearings, don't use race bearings for a road car. They're not really necessary. If the engine is going to have a hard life then use race bearings.
Discussion Starter #8
Thanks for the input people :)
I have another question......
I have a Haltech E8 ecu, cant find info on this site regarding this ecu on skylines, anyone used this ecu?
A conversion harness is needed unless its not compatible at all, please shed some light on this....
cheers
1 - 10 of 10 Posts
