1 - 7 of 7 Posts
I used a credit card to remove the GTR badge from the rear of the car so I could clean the area up.
All fine but what do you suggest I use to reattach the badge
Double sided sticky tape suggested which is keeping it in place fine. however Im pretty sure it will take very little effort to pull it off.
Any other suggestions?
Thanks in advance
Discussion Starter · #2 ·
Anyone?
Its raining and I have little confidence that the badge is going to remain on.
It looked to be previously held on with putty/glue type stuff. Any views?
"No more nails" double sided tape should work... (just needs to be cutout neatly) after a few days it should be rock solid.
(better than the run of the mill double sided tape, since its like a gum rather than a tape)
I ordered a spare badge from nissan, and from the looks of things it comes with a similar sort of tape backing on it to start with :D
i havent a clue..... maybe contact a sprayer and ask them as they would have to remove and attach badges when spraying.
sorry if thats no good though lol
Double sided tape for automotive... 3m brand works very good. It is also not a good idea to really to have the badge fixed in it's place coz sooner or later you need to remove it. Just like you when you clean the taped area, or when you need to repaint it, etc.
1 - 7 of 7 Posts
