1 - 8 of 8 Posts
Just started to get a little misting on my drivers side rear indicator:(
Can anyone run me through easiest way of removing and sorting this problem out?
thanks in advance,
p.s. it's an R33 gtst:)
Discussion Starter #2
Sorry should have been clearer, its not really misting more like condensation on the inside of the indicator.
To remove the rear light there are aroung 5 or so nuts holding the light in place which need to be removed. You will also need to remove the centre section with 'Skyline' written on it. There are a couple of nuts to remove. The centre section clips in, so needs a bit of a tug. The lights are stuck in with some nasty black mastic type of stuff. You'll need to heat it from the inside of the boot to soften it a bit. Once hot you should be able to slowly ease the light out.
Can't reall help on the misting, I bought a 2nd hand 1 for mine when it got cracked in the bodyshop. I'm told R33 GTS and GTR rear lights are the same.
SH*T!!
Well looks like new led ones then:p
Where from and how much am i looking at here??
Discussion Starter #8
Come on Newera how are we doing on this group buy??
1 - 8 of 8 Posts
