1 - 7 of 7 Posts
Good morning all what sort of money are you looking at to rebore a rb30 to 86.5mm, put on the piston rings, polish the crank and install into the block
Many thanks
Ben
Discussion Starter · #2 ·
Any one? :)
Tbh I can't see boring a rb30 block to 86.5 being any different to a rb26 there's a local guy who does all this stuff inc re lining the cylinders if needed for anything from £50 -£120
I have had it done and the garage have said £300+ :/
I have found out it is rebore, acid dip block and crank and polish crank then fit piston rings and put in block so i think £300 is ok
1 - 7 of 7 Posts
