21 - 36 of 36 Posts
Discussion Starter #22
Theres 2 gtrs in our car club both running nearly 900hp both use late model R33 gearboxes...
But they wont run slicks.
I guess thats not verry safe, A friend said that i should go with a light clutch and OS Giken/PPG*.
*PPG Rates their gearset at 900ps
I just dont know what the PPG costs :chuckle:
Discussion Starter #25
The PPG is available in helical cut (like the os) OR a straight cut dog box
The os gearkit into your R33 case would be the best value IMO
The PPG Dogkit was about 10k au last time I looked
5speed Straight Cut Dog Set - Nissan R32, R33, R34, Z32 - Pfitzner Performance Gearbox
10k AUD is about 67 000 Swedish Crowns so its over my price range but where can i find the exact price? What i was talking about was not the dog box it was this set Helical Synchromesh Gearset - Nissan R32, R33, R34, Z32 - Pfitzner Performance Gearbox
@ matty; if that is on a bog std OEM 6speed then that's very impressive :thumbsup:
Although synchro's won't last long when properly used on a track ;)
Agreed, guess it depends how its driven, there's a thread on here some were with a pole and pretty much everyone has a crunch!! And I bet most are running half that power!
If you baby it, it will be fine. But that's not drag racing, Is it?!
its the stock box with a few modifications
Gio says that the GT-R nissan and TS engineers were very impressed with the box
i questioned the internals and was given the spec, but its basically a stock R34 GT-R box, very very low mileage (original one with the car)
everytime i change gear it just feels so precise, hence why i thought it was uprated
but its done various dyno runs, top speed runs etc and its fine
Lost me there matt, is it a stock box or a uprated box.:confused:
If its modded, What mods does it have.
Thought OS did a uprated gearset for the getrag?
no its a stock box, the fork etc is uprated. but gears are stock
its just extremely low mileage, which probably helps
How low is low milage? 1000 miles? 5000 miles?
And when you say 'fork' as in the clutch fork that the clutch slave pushes against?
matt, if you read the spec on speedhunters thats the best really to look at
Or im sure Gio will help out, he is the one after all that built it :)
the car has 11,000 miles since new
21 - 36 of 36 Posts
