1 - 12 of 12 Posts
new decluttered for sale thread for my rb26 motor
motor was rebuilt by broadspeed services and I have receipts for work done.
spec of motor
87mm je forged pistons with oversized gudgeon pins approx 2650cc due to 87mm rebore
new little end bearings resized for oversize gudgeon pin
acl race big end and main bearings
all new gaskets and seals throughout
new water pump
oil pump stripped, inspected and rebuilt
new cambelt
cylinder block bored and decked
crankshaft checked for straightness and journals polished
motor was ran in for 1k miles at 0.5 bar. then ran 1.2 bar for 1.4k miles and that is it. excellent oil pressure as pictured below
i took some pics to show the engines excellent oil pressure.
oil temperature at time of taking pics of oil pressure
idle pressure
4500 rpm oil pressure
and with a pair of -7 turbos at just 1.2 bar of boost on mgts dynapack it made 415 hub hp, 387 hub lbft
i have the invoice from broadspeed services for the engine rebuild, co and hc were well within spec at last mot, she used no oil and ran perfect no exhaust smoke, its a win win as its been run in properly and dyno tuned and its perfect any issues would of shown themselves by now.
with some -5s the motor should comfortably run 550 to 600 hp as the pistons are now forged it can run more boost than a stock motor without fear of piston failure.
i will sell the motor as it sits for £2500
or bare tall motor with no ancilarries, inlet or cam/coil covers for £2000
Discussion Starter · #2 ·
engine complete as pictured above now £2400, or bare tall motor with sump but no top covers now £1900 bargain peeps ;)
Jesus Christ wept that is cheap with either sale option
cheers it is silly cheap really i just want it gone though, ive moved on got an r35 so have no use for it, the r35 has wowed me so much i cant see me ever going back :cool:
i will also sell bottom end for £1500, cylinder head with cams for £500, criminal shame to strip it though its as new !
i will also pallet the motor and deliver it worldwide at buyers expense.
Ah you see you made that fatel mistake of seling your RB 26 for the V38 !
Should have done what i did and kept both
Wish this had been available 2 years ago when mine failed !!
Steve
Discussion Starter · #6 · (Edited)
Steve
it has blown me away steve, I have no need or use for an rb26 they aren't even close to the same league as a vr38, mine is makeing 850 hp with minimul mods really :eek:
I have a 5.3 litre 1972 Chrysler v8 im rebuilding and a 1987 supercharged 2.8 capri zakspeed capri build to keep me busy, I have all my skyline needs all rolled into one perfect package in my r35 :)
I honestly don't miss my r32, r33 and c210 one bit lol
I was considering shelfing it but in all honesty there is no way I will ever go back, if I had an r32/r33/r34 again I would want an r35 engine and trans in it.
it is a bargain im amazed it hasn't sold, maybe its to cheap and folks think its to good to be true ?
**** **** **** you have just said some words that have sent a shiver up and down my spine Capri, Zack speed, Supercharged OMG if I was a woman I'd be wet !!!!
Here's an idea for you, I have always hankerd after going back to my Japanese roots and getting another 240z BUT with R35 running gear !!! Now that would be my perfect car !!!
I went through all of the proper Ford models and rallied Escort Mexico's and Mk2 Cortina's and even an Anglia !!!! then went through my Cossie days and Ohhhhhh reminising !!!!
Discussion Starter · #8 ·
a stage 3 cossie started me off mate in 1999 I was blown away by it and had to have one :)
I have a 50000miles 2 owner 2.8 special, a full sprintex supercharger kit, and a full group 5 kit being made includeing the huge rear wing :) how well I can fit it all we shall see :eek: lmao
il do a thread on here once I get started on it :)
1 - 12 of 12 Posts
