Sorry I didn't reply sooner.
The Fuel System is under construction really, just putting the parts together.
It will consist of;
- Stock Fuel Tank.
- Uprated In Tank Pump (Stock fitment) - Used as a Lifter Pump (Unknown Brand/Flow as of yet)
<lifter pumps fuel to 2Litre Surge Tank>
- Surge Tank with return, overflow, entry and exit.
- Bosch 044 External Fuel Pump After Surge Tank
- *Inline Filter* After Bosch 044.
- Fuel Feed Line in -8 Braided Line.
- Up to Y Piece connection Earl fitting in Engine Bay
- 2 Seperate Fuel Feeds for either end of a Trust Fuel Rail with 720cc Injectors.
- Return Pipe from Fuel Rail to Electrical Fuel Pressure Sender Unit for use of Electrical Fuel Pressure Meter.
- Then after Pressure Sender, return line goes to SARD Type RJ Adjustable Fuel Pressure Regulator.
- -8 Return Line to Surge Tank
Just want a good quality inline filter after the pump, There's quite a few from the Aeromotive stable with 2000lb/hr of fuel rating & 0.5 psi drop
, something like;
this one on Ebay
Would this be alright?
