1 - 6 of 6 Posts
What are the two smaller outlet pipes on the standard turbo's that go into a blanked peice of piping? is this something that would have been blanked off when the intercooler was put in? Or something I can use for gains?!
Lee
Might be hard to show on a picture but I will try and get one...
But basically you have the outlet pipes that come out of the turbo to the intercooler.. then both of these outlets 't' off and go into a slightly smaller bore pipe.. these go two into one like the main oulet pipe and down through the inner wheelarch next to the main outlet pipe.. but when you look under the wheel arch the end of the pipe is blanked off..
Lee
Skyline Section Manager
Ah, they are the re-circ dump valve return pipes, which, as you run with HKS SSV are redundant. Hence the blanked ends.
1 - 6 of 6 Posts
