Hi All
I have a load of exterior trims, weather seals and rubbers to replace including the very expensive metal exterior finishing trims.
Before i steam in, has anyone done this before and put together any guides or pointers? I'd like to do this and not break everything along the way due to missing a tab or fastener here or there. Forewarned is forearmed etc!
Any help is appreciated
Steve
Discussion Starter #2
Following on from this I have replaced my retainers and rubber seals and its not looking too bad. There is a gap in the picture on each side and I have got the trims as far as I can get them adjusted backwards. There's not much adjustment in them at all from what I can see.
Anyone else had the same? Was thinking of sealing with a small bit of black silicone weather seal (neatly obviously)
Steve
