1 - 20 of 58 Posts
Hi guys, just curious, whats needed to remap a stock R32 GTR Ecu ?
I have cables etc for doing Evo's and Subarus but wondered what is required to do a Skyline ?
Do you need to do it via eproms and burn them then fit to the car or can you "flash" the stock ecu directly ?
I know with the 200sx's you can but you must fit a nistune daughter board first, is that the case with the GTR too ?
Send it to me, I offer a 7 day turn around and give you a UK based map for 97R fuel with modded ign and fueling maps so it will lift its skirt and fly;)
Discussion Starter · #10 ·
All very good dave but the problem is I run alot of mods and its not just a stock setup ! LOL
I do my own mapping so wondered if it were possible to reflash my current phoenix mapped ecu to tweak my mid range.
Looks to be that you cant though ? So ill hold off and get a PFC or something instead :D
Discussion Starter · #11 ·
With the cost of a rb engine they should be mapped proper and not just a off the shelf chip try rising sun performance off the forum.they can map them.
Cheers but again I feel many have missed my point LOL
I do my OWN mapping and im looking for info on the equipment needed to flash the stock ECU not looking for somewhere to do it for me :)
I have all the required stuff i.e det cans, wideband etc as I have mapped all sorts in the past (PFC, Emanage, ECU Flash etc etc). I have never remapped a std ecu in a gtr though so wanted to know if my tactrix universal OBD 2 reflash cable would work on the Nissan for example or if id have to get a PFC and use my datalogit gear to do it
I have a PFC and Data Logit available;)
Mate you can not do it the way a evo is done with ECU FLASH you need a eprom emulater and then you need to find the maps they are not in a format like ecuflash is.:thumbsup:
You would need to remove the EPROM. And a wide band etc is not really enough.. You want a rolling road to do things properly. I've never looked at the standard maps but there is normally a fair bit if tidying up that you can do to factory maps with reasonable performance gains.
I'm not declaring I'm an expert when it comes to rb's.. I mainly do diesels and the odd na petrol..
Just buy a Nistune board , you get the software when your order a board , liv emapping , datalogging ability to muck around with closed loop area,s. change injectors and airflow meters.
very very good system , cheap as well.
Mark
Discussion Starter · #20 ·
Just buy a Nistune board , you get the software when your order a board , liv emapping , datalogging ability to muck around with closed loop area,s. change injecters and airflow meters.
Mark
Awesome ! Cheers mark, thats what I was getting at ! Wasnt sure if you could get them for the GTR or not :)
1 - 20 of 58 Posts
