1 - 6 of 6 Posts
Wanting to paint these while they are off, but found the paint on them is stupidly stubborn, Nitromors did bugger all. Wondered if anyone knew the best way to get the paint off, maybe a wire wheel on a drill but not sure if brass/stainless is best to use
Discussion Starter #4
It's pretty stubborn, the Nitromors didn't even shift any of it..may have to try some other stuff
You could just sand it down by hand with 600 then go to a higher grade like 1000 then primer then spray it, new paint should adhere nicely then and as long as it's flat and smooth all over the new paint will go on and look fine
1 - 6 of 6 Posts
