1 - 11 of 11 Posts
Four IIRC
2 on the top, clearly visible, one on the metal bracket towards the inside of the car, and one by the wing
there should be two nuts on the back where the connectors run. if you remove the indicator then with a small philips you should be able to get the two on the bracket against the wing.
Yep
I did this 2 weeks ago - bumper off for the bolt on the inside guard - or Im told that with a extension you can get to it through the brake vent opening on the front bumper.
Dan
Indicator = turn signal light?? (I`m norwegian...)
1 - 11 of 11 Posts
