Removing rear diff/need help
As the pinion bearing is possible gone and my diff and prop shaft is broken.
I was thinking about removing the diff before I get the new one,( I dont know when that will be,but I´ve found the diff and prop that I´ll buy) just to see how the old one looks and how much broken it is.
so I ask you guys/ladys who know...is it hard to remove the rear diff?
Cheers.
Teitur Yngvi "Dohc"
Very easy - about 1 hour as a DIY job with jack and axle stands,. Don't forget with the 32 the ATTESSA hydraulics are mounted to the top of the diff so you need to unbolt these and tie them up out of the way before final diff removal.
