I have removed the recircs and all the other stuff that comes with them as i wont be using them with my single turbo, but now need to blank off the pipe that the intercooler connects to where the recircs used to connect to on the drivers side.
Where can i buy a blank from? I have had a look around but cant find one big enough. It is 2"
Otherwise, is there a pipe i can buy that would replace the black hardpipe so i dont have to blank it off?
OR the third option. I have a Blitz bov but wouldn't I still need to block that pipe?
Skyline Section Manager
I have a bung you can buy. £10 posted?
I cut mine off and got it welded up, and pulled every thing else out, but then again my turbo has the BOV built in, so there is nothing in line.
PM'd you mate.
Do you need to use a BOV with a Dual Ball Bearing Turbo?
I will be running a Precision Dual Ball Bearing 6266. I was under the impression that BB turbos are OK without them?
