1 - 8 of 8 Posts
What is the process for removing the rear diff? Do you have to drop the fuel tank? Or is it easiest to remove the whole rear sub frame?
Exactly.
Be carefull, the diff is pretty heavy. You should really use a gearbox jack because you can't lift it from above your head when you're doing it on your own :)
Going to tackle this in a few days and wondering whats the beat way to clean the surface before installing new gasket. Should I use some sealant also?
1 - 8 of 8 Posts
