1996 skyline gtr33 rb26dett (stock engine)..ran oil low 2 quarts...sounds like marbles in top end under load.sound goes away at higher rpms(oil pump?) Where is the oil sending unit located. I want to put a guage on to see what oil press is.If it is the pump,Can i change it with engine in car? Car in in usa. Any help would be appreciated Thanks, John
oil sender is on the engine under the plenum. got a large rubber sock covering it.
oil pump is an engine out really, cane be done on situ but you still need to get the gearbox of to get to the 4 bolts behind the flywheel backing plate,sorry
