Was looking at my 'to buy' list for the car (which is extensive :chuckle: ). Was thinking about adding some larger fuel feed and return lines in good old stainless braid.
Firstly, once the lines are unfastened at both ends, can a new one be attached and 'dragged through' in place of the original or is it held/clipped throughout the car??
Secondly, what happens with the outlet/inlet plastic couplings on top of the fuel tank? Surely they need to be enlarged or replaced? Ideally I would like to remove them both and modify the top plate to accept 90deg Areoquip fittings.
Has anyone done this or can give me some advice on how to make things better??
Thanks,
TT
To answer one question, the existing line is clipped all the way down the car so dragging will not be possible.
The 32 is probably the easiest of all 3 models to access the tank top so modifying should be fairly easy.
So I assume the lines run inside the car. An interior stripout then?? :eek:
Oh well, something for the winter months perhaps.
Any more feedback would be appreciated
TT
