1 - 15 of 15 Posts
I've seen many GTR's with a re trimmed steering wheel but never usually straight.
Is it hard to get the steering wheel straight once been taken off?
I would have thought it's easy to get it straight. I actually hate alcantara steering wheels so haven't looked at any photo's, but seriously they are put back on pissed?
Did you mean in person or on pictures posted on forums/FB?
Administrator
on my 33, I can't get my re-trimmed wheel straight. The splines on the donor wheel are "out" by 1 spline. I assume I'll need to get the steering geometry adjusted to compensate. Might be a similar thing?
Mike
Was chatting to litchfield about this and when they fitted, they tend to do it with alignment also to ensure it is straight. I assume get your own wheel trimmed and replaced and it might be OK. But they are normally exchanged for speed
~I have just fitted an all leather flat bottom steering wheel. When you do it there is a straight line marking on the wheel and the car base so you line the 2 up after. Mine seems ok.
Same here, I fitted a MINES wheel to mine and there is a spline that signals the 12 o clock position, went on fine and I didn't need an alignment.
I spoke to Litchfield and they do recommend an alignment with it which I can understand with some wheels but personally I had no issues whatsoever. I also spoke to Tin whilst I was at Litchfields and he said the same.
It is the factory parts issue, very normal, when you swap a different wheel from different car, even they both are OEM, they could still have very much big chance not to straight, just need to adjust it with tracking. Not a big deal.
Do you know a good place around warrington as mine needs doing??
Had the same problem when mine was fitted, wasn't good for my OCD! Had to get a full wheel alignment done again to straighten it out. Wish I had know before, would have obviously done it all at once.
1 - 15 of 15 Posts
