The 1.2mm Tomei head gasket served just 2000km before the engine melted down. The gasket did not blow (there were zero oil or water leaks anywhere on the engine). Can I reuse the head gasket, or *must* it be replaced? I've heard both - that gaskets are disposable, and also that metal gaskets can be reused a couple times.
opinions? or is there a hard and fast rule behind this? I always thought that one benefit of metal gaskets was that (so long as they hadn't blown) you could reuse them a couple times safely. But what I've thought, has, well how shall we put this? not always correct
