1 - 8 of 8 Posts
Hi,
I've an R33 GTS-T and seem to be having problems with my reverse lights, they don't work.
As I move into reverse I notice sometimes they flash on but 99% of the time I get nothing. Any ideas where I start?
Bad earth, bulbs drawing too much current for the relay..as in someone changed them for brighter one's?
Aitch
seems the previous owner has put blue bulbs in the front and in the reverse lights changed one to standard clear but still no good
hi, as with most cars when u push ur gear stick into reverse it activates a switch which operates the reverse bulbs, theyre usually located under the gear lever or on the gear linkageunder the car, hope this helps.
1 - 8 of 8 Posts
