hi
im having the rocker covers on my engine sprayed
what i want to know is do i have to remove the "twin turbo " pipe? if so do i need to replace the gasket between it and the turbo?
i have new rocker cover gaskets,do i put these on dry or do you have to coat them in oil?
is there anything else i should know ie torque settings,screwing down order?
cheers
mr paranoid
Yes you need to remove the twin turbo pipe.
The gasket for the turbo pipe can be used again as long as you dont damage it.
And the rocker cover gasket is rubber if i remember correctly, you put it on dry. You should be able to use the same one, just clean it off when you remove it.
