1 - 17 of 17 Posts
The RSP Oil drain kit designed to help reduce excessive oil buildup in the cylinder head of Nissan RB20/25/26/30 engines. This is a common problem experienced on the drag,track and the odd road vehicle. This kit helps drain the oil back to the sump quicker instead of building up in the head where it can be forced out of the breathers.
The fitting fits into the back of the cylinder head once the core plug has beed removed. It requires 2 holes to be drilled and tapped and seals with a `O` ring. The fitting is slimline which means it will not foul on the bulkhead even on a rb30.
Full kit including aeroquip fittings and alloy or steel weld-on fitting for the sump. £161
Or we can supply just the head fitting with a -10 jic outlet. £55
Richard
hi, i want to buy you the second kit, the one with the machined fitting o ring 2 bolt and the jic fitting. how and where i can buy it???
These look great Richard, want!
bob
Hey Richard, cheers for the head drain parts buddy!
Have you any pictures of the kit installed on an engine? And of where the drain goes into the sump etc?
Many thanks mate.
bob
if it help you,from rips, i ordered a extended sump and an extra an fitting weld on it for the oil return line and he told me that he will weld it on the intake side and i imagine on top of the extended section
Awesome cheers Richard!
bob
1 - 17 of 17 Posts
