So I have finally finished my single turbo install, everything is all plumbed in and i was looking forward to starting the car and hearing it properly.
I turned the car on, the revs went up then dropped and the engine spluttered and cut out. I have had the car running previous to this with the single turbo (to make sure it was all ok, not driven) and it seemed to run fine but i have just recently taken the plenum off to remove some water lines and put it back on and also fitted a catch tank.
If i hold the throttle open it will run, although a bit lumpy and seems that its over fueling alot as its burning my eyes! Once its warmed up a bit it seems to stay on for a little while but start spluttering more and more till it cuts out again
If i pull the map sensor pipe out of its mounting hole (where the old PCV valve was) then the car seems to start idling fine, although a little high. If i put my finger on the hole the map sensor pipe goes into you can feel a strong vacuum and that brings down the revs to a normalish range (around 1k).
The thing with the blue port is where the map sensor plugs into and it screws into that hole
What is weird is that the car is running without the map sensor pipe plumbed in and a lot better than with it plugged in too!!!
A little run down on the plenum refit -
I bought new metal gaskets and sprayed them with hylomar.
Also sprayed the plenum and throttle body faces with it for some extra sealing.
I cant really hear any air leaks but the car is very loud and in the garage.
I am running a Link G4 ECU currently with the map that came with it when i bought it from someone on here. He was running 600cc or 800cc injectors, not sure which.
I am running standard injectors and i have not yet changed the settings on the Link to them so i know that could have something to do with the bad running but would it make the engine splutter and cut out?
I haven't tried spraying the inlets with wd40 yet as it got to late and there are babies next door so didn't want to wake them.
Anyone else have any suggestions? I have checked under the plenum and everything is 100% plumbed in.
P.S. If anyone has been reading any of my other threads i decided to keep the IAC and ICV for now so running everything under the plenum...
Also, is it OK to run the car without the vacuum pipes plumbed into the waste gates so i can drive it to get the exhaust welded up? It will not be seeing any boost at all and the springs are 1bar anyway. Pretty sure someone told me that you don't need to run a boost controller at all really if you are sticking to that boost range... Just wanted to confirm.
