1 - 15 of 15 Posts
hi
just wondering are you able to mate rwd block to awd sump want to upgrade my gts4 r33 n/a as i have a rb25det rwd motor??????
any feedback would be great
Skyline Section Manager
The blocks are the same so the sump will bolt straight on.
The RB25 and RB26 blocks have the same sump bolt patterns. You can bolt either sump (RWD-4WD) to either block. The 4WD sump needs a different crank girdle, there is a relief in the casting to accept the front drive shaft. You could mod a RWD girdle to suit.
Discussion Starter · #8 ·
dont mean to be a pain and this stuff has probly been answerd 100x before are there any threads or posts photos with comparisons of the blocks?
only the awd rb25 block has the same sump bolt pattern as the rb26. the rwd rb25 is the same as the other rb rwd blocks
Correct :thumbsup:
My RB25DET engine in my RWD GTSt fitted the GTR sump!!
Must have been a 4wd RB25det engine then??
It's not that I don't believe you Rob, I find it hard to understand why nissan would use 2 different block patterns for such a small different when the actual cost different would be negligible.
You'd think that but the 4wd blocks are totally different and they get a huge amount of extra machining.
Trust me, the 2wd blocks do not have the extra casted area along the sump rails or the mounting holes to mount a 4wd sump, hence the need for an adapter plate when wanting to run a 4wd sump on a 2wd block.
You can put a 2wd sump on a 4wd block though as they do drill and tap the 2wd pattern on the 4wd blocks.
Rob
1 - 15 of 15 Posts
