Hi,
This may have been covered before and I thought I understood the workings of the 4WD system on a GT-R.
My question is if you are going round a corner in a GT-R and you are using more than 10 degrees lock on the steering if you floor it is the GT-R in RWD mode or will it still transfer tourque to the front wheels too? I thought I read somewhere that the GT-R is only in 4WD mode when driving hard in a fairly straight line to give the best possible traction i.e. less than 10 degrees lock to prevent understeer..
