For sale is my 1999 (January build) Nissan Skyline GTR Vspec with 35,000 km. Comes in factory Nissan EV1 Lightning Yellow which makes this GTR rare even in Japan. Twin turbos, 6-speed Getrag, AWD, 2.6 liter with forged pistons.
For a great cause and because Paul Walker and the Fast & Furious franchise was such a big influence on the import scene 5% of the sales will be donated to Paul Walker's Reach Out World Wide (ROWW) charity foundation.
Car was featured on the cover of Sport Compact Car Magazine "Ultimate Street Car Challenge" issue (11/07 and 12/07) and Import Tuner Magazine (10/09). Exhaust sound was recorded and can be heard in Rock Star's 2008 video game "Midnight Club: Los Angeles". Can also be seen in the Turbo and High Tech Performance Magazine 2008 Calendar. Featured in the online video series "Bikini Driving School Episode 8". Many online features as well from GT Channel to Urban Racer. Was a show and display booth car at SEMA, Formula D, Long Beach Grand Prix, SpoCom, Hot Import Nights and many other events. Universal Pictures took photos of this car and an image was used in the Fast & Furious 4 (see photo).
Just installed CP forged pistons, new belts, and new engine and drivetrain fluids. Car runs flawless with an incredible power band that doesn't stop pulling. Very responsive and almost no turbo lag. Perfect street car with exceptional track capabilities. This is a well documented car build. Receipts, photos and references can be presented upon request to serious buyers.
Built, tuned and maintained by Aki Fuchigami, GMG Racing, and formerly Garage Bomber Japan.
Engine Code:
RB26DETT
Type:
2568cc, inline-6, Bore x Stroke (mm) 86.0x73.7
Internal Modifications:
ARP rod bolts
Head ported & polished, seat cut, surface cylinder head, & valve grinding
PBB valve guides
Apexi 1.1mm metal gasket
Tomei Pro camshafts
Tomei lifters
Tomei valve springs
Red Line 15w50
Reimax camshaft cover baffle plate
CP pistons 86mm 8.5:1
ACL race main bearing and connecting rod bearing
External Modifications:
Garage Bomber port matched intake and exhaust (head and turbo side) manifold
NGK race #9 spark plugs
Apexi cam gears
Apexi fuel pump
Apexi twin intake 80mm
ARC catch can
ARC 80-100-130mm titanium exhaust
ATI crank damper
Garage Bomber aluminum hot pipe
Denso 720cc injectors
HKS twin GT2530 turbos w/ heavy duty actuators
HKS fuel pressure regulator
HKS fuel rail
HKS 70x2 ->80mm SS down pipe
HKS Type-R intercooler
Koyo race aluminum radiator
Nissan N1 water pump
Nismo hard pipe kit
Odyssey PC680 battery
Reimax throttle valve shaft bearing seals
Sard fuel pump relay
Setrab 25 row oil cooler with custom ducting
Tomei oil pump
Tomei oil pan baffle plate
Tomei 76mm turbo outlets
Tomei timing belt
Trust radiator cap
Nissan twin 300ZX Z32 MAF
SamcoSport silicone hose kit
Engine Management Modifications:
Apexi Power FC w/ Commander
Garage Bomber tuning (Dyno Pack 618 whp, 448 lb/ft torque) at 1.4 bar on 100 octane pump gas
Layout:
Front engine, all-wheel drive
Drivetrain Modifications:
Carbonetic front 1.5 way carbon LSD
Exedy twin-plate clutch and lightened flywheel
Red Line ATF
Red Line gear oil
Red Line power steering fluid
Front Suspension:
Cusco negative upper arm
Nismo anti-roll bar
Adjustable Coilovers
Rear Suspension:
Cusco upper arm
Nismo anti-roll bar
JIC traction rod
Front Brakes:
Endless 6-POT 278.5mm racing calipers
Endless 355mm cross slotted rotors
RBF Motul 600 fluid
Stoptech SS brake lines
Cusco master cylinder brake stopper
Rear Brakes:
Factory 2-POT Brembo
RBF Motul 600 fluid
Wheels:
Enkei RPF1 SBC 18x9.5, +15
Nismo long wheel studs
Project Kics R40 racing lug nuts
Tires:
Yokohama Neova 285/35/18
Body:
Car F1 carbon fiber front diffuser
Garage Saurus carbon fiber trunk lid
Garage Bomber rear spoiler in-trunk support
Garage Bomber custom front and rear steel tow hooks
Nismo LED tail lights
ARC aluminum rear diffuser
Interior:
Mackin titanium shift knob
Blitz SBC ID3 boost controller
Apexi turbo timer
Apexi Commander
Nismo floor mats
Located in California, USA. Priced at $59,995 USD.
Engine Code:
RB26DETT
Type:
ARP rod bolts
PBB valve guides
Tomei Pro camshafts
Tomei lifters
Tomei valve springs
Red Line 15w50
Apexi cam gears
Apexi fuel pump
ARC catch can
ATI crank damper
HKS fuel rail
Nismo hard pipe kit
Tomei oil pump
Tomei timing belt
Trust radiator cap
Layout:
Red Line ATF
Red Line gear oil
Front Suspension:
Nismo anti-roll bar
Rear Suspension:
Cusco upper arm
Nismo anti-roll bar
JIC traction rod
Front Brakes:
RBF Motul 600 fluid
Rear Brakes:
RBF Motul 600 fluid
Wheels:
Tires:
Body:
Interior:
Apexi turbo timer
Apexi Commander
Nismo floor mats
