61 - 80 of 125 Posts
Thanks for the iso's. I'm getting the same error. I have another java executable that I can just double click on & it opens - I take it there is no way to make it that easy?
Hi there - I've only had my 11 plate for around a week and would be keen to do this update.
I have downloaded all the ISO files and pretty sure I can burn these to disc but not so sure what I do with the mugi files. Any advice? I run a mac if that's of any relevance?
Thanks,
The reason im getting R35 Audio to do it is that you are all speaking Latvian as far as im concerned LOL
Thanks, however I tried all that but get the following error...
C:\Users\someone\Desktop\mugi>java -cp . -jar .\Mugi.jar
Error: Could not find or load main class Mugi
Sorry, I have the same problem, appreciate your advice...
I originally circulated the first set of discs, was easier then !
Its out in the open now so fsck it
$ java -jar ./Mugi.jar 10123545678901234567890123456789 << this is the first disk dvd key 10123545678901234567890123456789 <<<< unit id padded with four byte on the end add 2 on the end to generate two license keys
449A65D5B8A6883E
0092AE9E0F16961C
2 NUMBERS: 1 ms 2
exampls
$ java -jar ./Mugi.jar 10123545678901234567890123456789 10123545678901234567890123456789 2
449A65D5B8A6883E
0092AE9E0F16961C
2 NUMBERS: 1 ms 2
449A65D5B8A6883E
0092AE9E0F16961C
2 NUMBERS: 1 ms 2
exampls
449A65D5B8A6883E
0092AE9E0F16961C
2 NUMBERS: 1 ms 2
I would love to say this is crystal clear to me but can I ask what may be a stupid question. Have you basically run the JAR file and given us the keys? :lamer: Namely:
449A65D5B8A6883E
0092AE9E0F16961C
If so :thumbsup::clap:
449A65D5B8A6883E
0092AE9E0F16961C
Kind of, everyone's nav unit ID is different and so you need to supplement that for my example above.
Also each DVD key is different depending on what version you have.
Thanks shavermcspud. Is there a chance you could drop me a PM so I can just clarify a few things. I think, as I'm new, It won't let me PM yet.
Thanks for your advice :thumbsup:
Sorry to be a pain but where is the DVD key - does it show on the display or is it in one of the iso's.
Also how many digits in the DVD key & unit ID just so I know I have the right ones?
System disc is updated & working fine Thanks for your help!!:thumbsup:
The "DVD key" is the 32 character MD5 checksum of the first DVD .iso file. c72449636ef88b0c758e943626b97383 if using the files in the above link.
The Unit ID is 10 digits long. You don't include the hyphen.
Thanks to shavermcspud I have this license generation software working but sadly none of the activation keys it generates seem valid.
You're not alone
What's this update?
The 2017 system software update DVD for the Nissan Connect X9 audio/satnav head unit. Someone kindly posted it in the form of a .ISO file which can be burned to a DVD and then used to upgrade your head unit. Sadly the accompanying navigation map updates are a work in progress as they need a license key coded to the unique unit ID of your head unit. We all got excited when it seemed someone had a license key generator. :(
This stuff costs £150 from Nissan normally.
Is it a lot better? And works ok with the earlier system?
:thumbsup:
Still no luck even with the md5 as the DVD key so if that is the correct key it must be something to do with the unit ID if it has worked in the past. still at least we got the system disc to load so not all bad
Fantastic work shavermcspud,
It would be great if someone who has successfully made this system work, could write an idiots guide to show all steps, including which files to burn and which order to use the discs and exactly how to use Java if you have never done this before.
It seems many have not been successful, is this because they are unfamiliar with the process so far described.
I have never used Java, so it is very unfamiliar to me and no idea how to do this.
Hugh
