Hi,
I have a scissor lift at home which I wanted to use on the GTR. On all my other cars the jacking points sit proud of the side skirt, so it’s a case of drive on and simply lift.
The GTR jacking points seem to be set so that the skirts are actually LOWER - so obviously cannot lift as it would crush the side skirt - and Idon’t have enough space to put some jacking pads underneath.
Not sure on best way forward - anybody else have experience here that could help?
You can get adaptors off eBay to use, I bought mine ages ago so can***8217;t recommend it remember the place but a little search will help
Thanks, what I did was drive the car onto the ramp and at the same time with wooden planks underneath each wheel - that gave me tons of clearance. Put my rubber jacking pads in and it was spot on :)
I might still get the adaptor things you mention as I had to take a couple of goes to ensure th side skirt wasn***8217;t being pinched.
