I wasn’t sure if there would be interest in this here so originally did not post a build thread but after the reaction to a few pictures I have shown I’ll post the project thread up.
The aim for the car is to be a light weight powerful top level drift car that is easy to drive with completely linear responce
To give you a taster
From this to :-
To this
As if we haven’t got enough to do in between our day jobs and running PPS, we decided to go ahead and build a drift car…:wave:
Car / Shell / Chassis - We have discussed the idea many times before even starting the breaker business. We wanted both the shell and engine to be different so we decided on an s15 shell with an s13 front end. Looks wise, inspiration came from the S15.3 MASA car.
We hadn’t seen many around at that time (still haven’t seen another one ?) and we both think it looks ace, ours will look somewhat different though as we are using a combination of parts and panels to get ‘our’ look.
Engine - Power plant wise, again, we wanted to be like everyone else and do something different, so a supercharged RB30.
So, on with the search for a 15. A bit of effort later I found one in Japan through Power Vehciles with light front end damage and a few goodies already bolted on.
SARD blade roll-bars
Zeal coilovers and cusco adjustable arms
Several weeks passed and finally it arrived at Liverpool docks so we took a day off work and nipped up to fetch it.
All sorts of other cool stuff in the car park...oh and there were some Impreza's aswell...
Back James's place we got to work stripping the interior. EVERYTHING went and the shell was totally stripped bare. Sound deadening was removed quite painlessly by getting up early on a cold morning and air chiselling it off. Then the remains were disssolved with white spirit. It was all off in a day
Note that the sill cavities seem to be filled with stiffening foam, an indication that the car has had competitive past perhaps ???
From this to :-
To this
