I'm about to fit a set of MeisterR GT1 on a BNR34. Very happy with the overall quality.
Anyone on here fitted a set ?
I'd like to know what length I should set (E) on the picture for front and rear to lower the car 20mm than OEM ?
Factory length on front is 35mm and rear is 200mm. Does anyone know the corresponding ride height with this settings ?
Get it on the car first, and adjust from there.
Because all the car weight a little different, and so sit a little different.
Once the suspension is on the car, then you know exactly what to adjust to get to the ride height you want.
Just make sure the springs are pre-loaded correct (2mm) before installation, makes life alot easier.
Jerrick
