1 - 20 of 46 Posts
As advertised on www.svaimports.com
(direct link http://www.purplematter.co.uk/sva/details.asp?ID=71 )
..anyone else seen this?....lovely, it doesnt get any better...Its alot of money but, wow. :cool:
The Ultimate R34...
2002 model
1800 km
1200bhp @ 2.6 bar boost
HKS racing 2.8L high deck complete engine, 1 of only 2 in existance
HKS head system STEP Pro V lifter, HKS STEP Pro IN/EX 296deg
HKS STEP Pro valve springs
HKS STEP Pro V valve IN set
HKS STEP Pro V valve EX set
Valve step seal set
Fully machined and modified head system
HKS GT3540 twin turbo
HKS special racing wastegate
Custom stainless wastagate outlet pipe
HKS metal head gasket
HKS oil pump
ATI crank dumper pulley kit
HKS GT intercooler cooler twin entry type
HKS oil cooler kit
TOP SECRET GT intake plenum
NISMO engine mounts
AUTO SELECT oil sump
Custom titanium exhaust
720cc main injectors X 6 + 440cc extra injectors X 6
Twin injector adaptor
BOSCH external fuel pump X 2 + SARD intank fuel pump
Custom collector tank
EARL'S braided fuel line
HKS fuel rail
HKS fuel regulator
Aluminium triple layered radiator
BILLION swirl pod set
SAMCO radiator hoses
BILLION electric fan X 2
OHLINS adjustable suspensions
S&S ENGINEERING pillow ball front arms
AUTO SELECT suspension arm pillow ball kit
HKS triple plate clutch
NISMO diff mount
NISMO member bush
13 point roll cage
Seam welded shell
AUTO SELECT frame support bar
RECARO Pro Racer SP-G bucket seat (driver side)
RECARO SP-G (passenger side)
HKS F-con V-pro ver3.1
HKS ETC torque split controller
HKS A/F knock amp
HKS EVC Pro
HKS turbo timer
TOP SECRET front bunper
TOP SECRET front carbon under diffuser
NISMO GT carbon bonnet
TOP SECRET carbon GT wing
TOP SECRET limited edition 18inch rims (VOLK RACING LE37)
NISMO LED GT tail lights
Price: £74995
It could possibily be the best specd car to ever land in the UK.
Blow Dog said:
Andy, what makes this car special?
Is it the engine, and what's special about 2.8? Is it better torque?
maybe....
1200 bhp sounds a lot of power Cem. I am sure you are after something that will do a few more miles inbetween rebuilds ;)
Awesome machine,, Though model report or not I wouldn't fancy stripping and rebuilding to standard for the ESVA, then back to its original spec after the test is done.. Might add a few quid to its already impressive price tag!
I've heard rumours that there is a model report for the R34 GTR, but it has to be 100% standard as from what I understand every part has to be in the model report, so if for example it has a HKS exhaust, there needs to be a model report for an R34GTR with a HKS exhaust, etc.
Alex B
lol thers more than two lmao
thers one on signal autos drag, the hks drag, that car, and...........
andys new dragger lol.
but yes the engines are very special
I think your correct Alex, the car has to be standard. I'm not sure if theres a model report available, I've heard a report was under prepartion but not available just ye
I can´t see that they´ve upgraded/changed the gearbox? Seems a bit strange considering the other mods done to the car... :confused:
/P
Andy.
I have been looking at this car for a week now but the lads in Japan are on holiday as you know.
I might bite the bullet and go for the ultimate weapon.
Mick
Banned
/P
They must have. Can't see a standard box taking 1200hp unless they've limited boost in the lower gears.
That is one sweet car!
Are there any better pictures of it, wallpaper needed :)
No just 1 small one, some one must have some decent pics of it...
1 - 20 of 46 Posts
