Do the g/b shift lights work on UK cars or is mine just duff?
(and yes it is on auto so should be working!!)
Its a long while since I looked at this and dont have the manual to hand, but I think I recall that if you have it set to auto, you will only get a light at red line. If you want green and green flashing, I think you need to change from auto and set the rpm.
hazaerdous has it right. you have to set an RPM and it will blink 500rpm before i think
Discussion Starter #4
Right got it, yeah it is along way to the red line isnt it?
Set it to manual, 3k rpm just to see, and they do work, thanks.
Moved it to 4k now for road use, as frankly that could get you in enough trouble.
