361 - 380 of 395 Posts
Discussion Starter #361 (Edited)
ARC Slam panel - yeah or neh!
Hi Guys,
managed to locate a rare ARC Titanium slam / cooling panel for Shrek, not sure if I should have gone for the Nismo 1/2 carbon panel instead?
what do you think?
Anyone have a Nismo panel for sale / swap?
I'll get a friend to post pictures shortly - before & after.
:thumbsup:
I really doubt if anyone here will have for sale or exchange the Nismo panel you are after. The quality will be very good but I am led to believe it is designed to work alongside the optional air scoop designed for the R Tune bonnet..
ARC panel looks ok. Have you considered the Garage Defend panel??
Discussion Starter #365
Didn't realise that the Nismo panel may not work with a std V Spec II bonnet - I need to investigate - thanks for the info - and I will check GD.
Sorry JPS.. I should have made myself more clear; the half panel will work with your bonnet. The reason it is half length is because of the optional air scoop for the R Tune bonnet.
yes that,s correct if you have the Nismo z tune bonnet with air scope ,that hangs a lot lower and protrudes further forward than the scope you have so you cant fit a full panel with that set up ,but with what you have there there should not be no problem with fitting the other panel i would say .
It fits ok with your set up but is designed to work with other Nismo parts hence half panel
I have one (new) here
It does not have a part no so you have to either visit Omori or send them a fax / call
Most of the ***8220;bespoke ***8220; new items don***8217;t have part nos
Ie the rear tow eye
Super Moderator
Personally I think you should get a Garage Defend panel, it's by far the most beautiful and much prettier than the ARC.
Looks better with the arc panel in place
Does anyone have any pics of the GD panel that they could post up?
