and me. Mine has no switch on the main rad (r34 gtr)really thought that fan was dedicated to the air conditioning
have you a standard or after market rad mateand me. Mine has no switch on the main rad (r34 gtr)
well thats wrong. just looked at standard rad an it does have switchso basicly an after market rad comes with hole for rad switch which is used (if need be) for aftermarket electric fans !! can someone confirm this for me please , regards dave
LOL, so am i! Guess mine is different being a nismo rad then? But im also missing any wiring that should be there? Unless they have moved the sensor else where for a different sensor ? Hence i have no left over wires/plugs?well thats wrong. just looked at standard rad an it does have switch
CONFUSED
Thank you very much,,, no more confusment lolThe R32 and R33 have the switch in the radiator to switch the aircon fan on if the water temp gets too high. The R34 switches it via the ecu so does not have a temp switch in the rad.
Richard
