Hi guys,
After battling all week trying to get the standard twins off, I finally got them off this afternoon! My arms are ripped to shreds and my knuckles sore but it will be worth it in the end!
I am now at the point of fitting the oil lines and also need to know what to do with the old water lines as my turbo is oil cooled only.
I need to know where these bits go, if any one could help that would be great. Sorry for my n00by questions but I haven't done anything like this before so I basically don't know what I'm doing!
Does this go on to the turbo for the oil drain?
Does this screw into the block where the first turbo oil drain was?
Does this screw into the oil feed on the turbo? What end take the pipe? The domed end?
Does this go into the block where the two oil feeds are? How do you block the other side off? Or do you take the T bit out and screw this in there?
What is the best thing to do with the water lines? I have these left over. Is it best to remove it all from the back of the head to the plenum? If so any tips on doing that? If not how do i loop that to the front of the plenum?? Or if I do remove it from the back of the head, again, how do i loop it to the front? What size piping will i need etc?
Massive thanks for any help in advance!!!
