Hi!
I would like to know your opinion for this:
Iam going to build single turbo setup with aircooled turbo. So... should i take off old water lines or make new "pass" lines for them? If i only plug these lines, how it will act with coolant cycle?
Water comes from block to the turbo, and then it goes in front of the engine, and in the back too.
All answers are welcome.
block the pipes off :) Did the same when i converted my R32 GTR to single turbo. and i removed the pipe from from behind the engine to and closed the original boost controle pipes.
