Status
Not open for further replies.
Banned
!!!!JUST FEATURED IN REDLINE MAGAZINE!!!!!!!
CHEAPEST HIGH POWERED GTR IN THE UK!!!!!!
SKYLINE R32 GTR 1992 EX DRAG CAR FROM JAPAN CAPIBLE OF OVER 800BHP BUT HAS BEEN TUNED DOWN TO 650BHP FOR THE UK ROADS
ITS HAD RBUILD ENGINE AND REBUILT GEARBOX IN THE LAST 5000KM SO ITS READY TO GO!!!
Trust T88-34D Turbo Kit (Rebuilt same time as engine)900bhp
r32 block
Head drag ported oversized exhaust ports
87.5mm forge Pistons
steel Con Rods
Fully balanced Crank
Modified sump/oil pickup
HKS 1.2mm metal head gasket
n1 Uprated oil pump and water pump
Apexi V-MAX Step 2 cams (270 duration 11.4mm lift)
Apexi V-MAX Valve Spring Kit
Apexi Valve Lifter Kit
1000cc injectors
HKS fuel rail
2 x Atec fuel filters
2 x In-tank Nismo fuel pumps
Greddy 16 row oil cooler with remote oil filter
Greddy intercooler
Greddy uprated ally radiator
Hks uprated cambelt
Greddy Type-R BOV (with stiff spring)
Samco coolant hoses
Trust front pipe and exhaust
HKS Super Powerflow Air filter
Oil catch tank
greddy clear cam cover
hks adjustible pulleys
Drive train:
R32 5 Speed box recently refreshed
OS Giken triple plate clutch
Uprated LSD's (F & R)
Chassis:
HKS Hiper Drag suspension
Drag modified rear subframe
Nismo front suspension bushes
Endless brake pads
Hicas lock bar
10 x 18 volks style Alloys
265/35/18 yoko advans Tyres
Electronics:
Greddy fuel pressure gauge
HKS F-CON V Pro GOLD ECU (AFM's have been removed)
Greddy boost controller PROFECT B
Apexi 60mm Boost and EGT Gauges (with peak hold)
Line lock
hks oil pressure gauge
Interior:
full 6 point cage
Momo sports steering wheel
NISMO shift knob
Robson leather carbon-look gear shift and handbrake boots
cobra monco seats and rails
Hicas, ABS & Air Con hardware have been removed
New dash vents
outside
top secret carbon bonnet
as carbon canards
as carbon front lip
nismo rear lip
new cambelt and idler pulleys was fitted this week ready for another 100k
All the work was carried out to a high standard must have cost in excess of 50k to build
the car is excellent and ready to use i also have all power read out for 650bhp when it was mapped in the uk
£11995 PLEASE NO OFFERS IF YOU CAN'T AFFORED THE PRICE THEN YOU CAN'T AFFORD TO RUN A BIG POWER CAR
Status
